will someone go over the process and tools required to sharpen your lawn mowing blades
how to sharpen blades
Magna-matic has the MAG-9000 for sale for $610. If you can't afford that then I suggest using a wet stone grinding wheel. This will help to keep the heat down. Any time you overheat the edge of the blade you're ruining the temper of the steel and making it brittle. Other than that it's just about getting the angle right and keeping it balanced.
Magna-Matic grinder, Magna-Matic balancer. Please see the included directions.
WoodyWoody
http://shop.store.yahoo.com/tylertool/del311beland.html
I've been using a 1" Delta belt sander for three years now with zero problems. I run double blades on three-four walkbehinds changing blades daily. I probably sharpen about 50 blades a week right now. We can get them razor sharp and perfectly balanced. I've had a couple sets of blades for three seasons. I'll take a picture next time I think about it.
Here are a couple blades sharpened on the belt sander. I've never used a dedicated blade sharpener or balancer so take my advice for what it's worth. I don't know they may be a hell of a lot better, but I don't see how you could possibly get any sharper than these.
I've been sharpening tools since I was a kid and nobody has ever really showed me "proper technique" if there is such a thing. My dad made my brother and I sharpen the mower blades when we mowed, and there was always something to be sharpened on the farm.
You talk about pissed off. I knew the lawn had to be mowed by Friday evening or I wasn't going out, and he knew that I knew, but wouldn't say anything. Of course we'd wait until the last minute to cut the lawn, but then to top it off we had to come in and sharpen blades before going out for the night.
I just haven't been able to justify spending $1000 on a blade sharpening system.
Please note that a belt sander is very slow compared to a dedicated grinder and balancing on a nail is pointless. Everything from belts to engine to drive components to cut quality is affected by the vibration caused by unbalanced blades. If one uses the off-set blades pictured by Mr. RRS, please purchase the Mag 8000 along with a 1000 balancer; a bearing loaded, magnetic, cone type balancer.
http://magna-matic.com/Merchant2/mer...tegory_Code=CP
Originally posted by CandibearRRS
Wow really appreciate your input on this one it goes to show sometimes you can get by the old fashioned way. especially for people that just can't justify $1000.00
Thanks
If you're just starting out ... you are sometimes forced into doing things the hard, slow way ...then later on ... faster methods make sense and you can't afford to be without them.
Just common sense ...
