I have a IIC 800 PL controller and Program "A does not work, "B" and "C" work fine but "A" will not activate. Any suggestions?
Hunter Controller
I'm sure you've checked, but is there a start time set? About about scheduled days to run? Can you manually run Program A?
You might also try to reset the controller.
1. Hold down the (-) button, the (->) button, and the (PGM) button simultaneously.
2. While holding down the three buttons, press and release the reset button on the back of the front panel, then release the three buttons.
This is clear out everything on the controller and it'll need to be reprogrammed entirely so make a note of settings to be re-entered beforehand.
Sounds like a bad controller if everything else checks out fine. Unless you need all three programs, just use B and C for the scheduling needs until everything else craps out...or just install a new controller. I'd recommend a Hunter Pro-C if you have less than 12 zones. :alien::alien::alien:2008, 2009, 2010, 2011, 2012, 2013, 2014 and future 2015 LSF RECEPTED AWARD recipient!
