new pressure washer
  • new pressure washer
    Hi there,
    I was thinking of getting an electric pressure washer and wanted to know if you had any favorites. I was hoping to get one I can use for different surfaces and which makes it through the tiniest corner.
    I had a look at websites like this but there is so much variety and different price ranges that I just dont know what to get. What do you think? Can you recommend any of the brands or types?
    Thanks for your help.
    Get the most gallons per minute you can afford.
    Quality Is Good
      Gear Cutting
      Gear Cutting is the process of creating gears . The Most common process of gear cutting includes Broaching, hobbing and Machining.
        Pressure washers are rated by pressure (pounds per square inch: PSI) and flow rate (gallons per minute: GPM). The power of a pressure washer is measure in cleaning units (CU). CU is calculated by multiplying PSI by GPM. A higher CU indicates more cleaning power. Take this points into consideration when you decide on what to purchase and you'll never go wrong.
          At first be very careful about the electric wearing system of your house.
