Jack D. invited me to post my driveway snow removal machine. I do like his machine, but I do know mine will remove snow much faster, and better.
This machine will not be slowed down by any amount of snow. This machine turns in the same amount of space as an Exmark with a blower attachment. This machine has as much down pressure as you could need. It is has 4 wheel drive operating off hydros. This machine can actually get closer to garages than a blower. You don't have to stand to operate this machine. You will not have blowing snow on you when operating it. You are protected from the elements. It has a diesel engine and block heater. No human strain is needed to operate this machine. This machine has 2 standard lights in the front, and one in the back.
This snow remover doesn't need weights for traction. You don't need to add snow tires. You don't need to add hand warmers. You don't need to add batteries, lights, wires, metal rods. No need to add a remote this or that. No need to change fluids for cold temps, or wire for heated carbs. No need to spend countless hours switching it back to a mower.
Weighing in at under 2000 pounds, it can be hauled around by ANY truck on the market. I have even seen them backed up onto the beds of full size trucks.
This unit performed better than I had ever planned. Pull up to the property, sit in the machine, start. Drive right over the snowy driveway up to the garage. Drop plow within 1 inch of garage door, put down pressure on. Back up 6'. Spin and back up onto clean pavement, drop plow and drive out the driveway pushing snow out. I then push that snow over to the side. I would have to time it, but my guess would be 100' driveway in 2 minutes? Figure one strip is all it takes. Of course, the plow will also angle if needed.
Notice that the machine is on a 12' trailer. So you can see by the dimensions, it's not very big, but has a lot of power. Notice it can easily be pulled by a small Nissan.
And to put in the last jab. It has a 7' plow that will allow you to also remove snow on smaller commercial lots faster than a truck with a 7.5' blade.
