Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 66
Thread: The Ultimate Garage Fronted Snow Removal Machines.
  1. #21
    Join Date
    May 2003
    Location
    North Central
    Posts
    2,527
    Default Important Announcement.
    Mr. ba1m2x2 has had difficulty posting a pic of his blower so he has forwarded the pic for Jack D. to post for him.
  2. #22
    Join Date
    Jun 2005
    Location
    Maine
    Posts
    59
    Default
    Its beautiful!!!!!!..........however...I would have used Pressure treated plywood.
  3. #23
    Join Date
    May 2003
    Location
    North Central
    Posts
    2,527
    Default
    Quote Originally Posted by Scaper-S2k
    After carefully reading through this thread, I am confident that the machine dubbed as the 'Ultimate Garage Fronted Snow Removal Machine', falls short of the true winner......MY ultimate snow removal machine.
    More info to come.
    We are either going to see a pic of Mr. Skaper's bloated 2WD cabover w/plow or a Jeep Wrangler w/plow or an ATV w/plow or a skid steer w/plow or blower.
    We also could see a pic of Mr. Skaper's Nissan Frontier w/front plow and Rear Backdrag plow or a front Hiniker C-Backdrag plow but Jack D. doubts that Mr. Skaper has advanced to that level.
    Whichever Mr. Skaper chooses, Jack D. will enjoy illuminating the units limitations compared to the effortless maneuverability and compactness of a dual hydro walk blower.
  4. #24
    Join Date
    Apr 2004
    Location
    FL
    Posts
    1,215
    Default
    apprentice fabricator, you are not.......
    glad someone relayed you just installed it, rather than "invented" it....
    GEEVEE«, Pat.Pend. TM, UL
  5. #25
    Join Date
    Mar 2003
    Location
    earth
    Posts
    1,579
    Default
    Quote Originally Posted by Ric
    Jack D
    I suggest you patten your ideas on pimping these snow blowers and not give away your fine Ideas. Abe Goldfarb is the Patten Attorney you should use.
    I believe you mean Rube Goldberg or Rube G. as he likes to be called by us Green Industry Scrubs.
  6. #26
    Join Date
    Dec 2002
    Location
    Hurricane Heaven
    Posts
    2,683
    Default
    Quote Originally Posted by hardboiled
    HardBoiled
    One of the nice things about being a senior citizen is, You can blame your stupidity on age. Yep I bad and you are correct Rube Goldberg is the attorney I was recommending to Mr Jack D.
    I just see a lot of Afro Engineering with the battery in the back of the see-saw and extra weights in the front to counter balance. If I may call your attention to the picture in post # 6. Is Jack D using a wire to pull his spark wire off as a kill switch??? Does Jack D have enough liquid electric tape on the solenoid???
    You can lead a donkey to water but you can't make the Jackass drink.
  7. #27
    Join Date
    Mar 2003
    Location
    earth
    Posts
    1,579
    Default
    In most cases a wire attached like that would mean the owner has installed an electronic tacho/hour meter. In that case the installer would wrap the pick up wire around plug wire 3-4 times and secure with a cable tie. However, you may be correct, that in this case, it is there as an alternate OPC. The other end must get tied to a finger or other small appendage. This way if the blower starts to head down stairs, a simple step backward will shut it down.
  8. #28
    Join Date
    Dec 2002
    Location
    Hurricane Heaven
    Posts
    2,683
    Default
    HardBoiled
    The Picture in post # 3 of the dash board or control panel does not show so much as a hr meter let alone a tach. I am sure Jack D ties the other end of the wire around his short privates and lets go of the machine every time he sees or thinks of a young lady. That way he gets a thrill and at the same time doesn't lose control of his machine.
  9. #29
    Join Date
    May 2003
    Location
    North Central
    Posts
    2,527
    Default
    Interesting that both Mr. ba1m2x2 and Mr. Skaper claimed they owned the Ultimate Garage Fronted Small Residential Snow Removal Machine® and would post pics of said machine.
    Where are they now ?
    Hiding in shame no doubt, never to be heard from again.
  10. #30
    Join Date
    May 2003
    Location
    North Central
    Posts
    2,527
    Default
    Mr. Hardboiled is correct. The unit sports a Tach/hr Meter.
    Mr. Ric is advised to put on his hat and not let the door hit him on the way out.
Similar Threads
  1. The Ultimate Res. Garage Fronted Snow Removal Machines Will be Revealed Friday.
    By Jack D. in forum Snow Removal & Ice Management Forum
    Last Post: 01-15-06, 07:57 PM
  2. Jack D.'s Residential Snow Removal Bad Boys Will be Completed This Week
    By Jack D. in forum Commercial Lawn and Landscape Maintenance Forum
    Last Post: 12-29-05, 02:03 AM
  3. Only 5-10 More Days Until the Unveiling of the 4 Ultimate Small Res. Garage Fronted
    Last Post: 12-16-05, 02:10 PM
  4. Snow Removal Help Needed
    By MGO in forum Snow Removal & Ice Management Forum
    Last Post: 10-08-05, 03:54 AM
  5. Residential Snow Removal
    Last Post: 02-13-04, 05:57 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
