Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: What does milky white hydrolic fluid mean?
  1. #1
    Join Date
    Jan 2009
    Location
    Kansas city
    Posts
    10
    Default What does milky white hydrolic fluid mean?
    I last used my plow a week and a half ago. I went out to test it today(an old Meyer I bought used) and it would not move in any direction. I bled off the fluid and it was milky white. I refilled with new fluid and it is working now. I'm wondering what would make the fluid white and why would the plow not move? There is one place on one of the arms that it leaks fluid just a tiny bit, but no big puddle or anything. Does anyone have any experience with this?
    Thanks.
  2. #2
    Join Date
    Nov 2003
    Location
    Eastern LI,NY
    Posts
    1,362
    Default
    Either air or water mixed in with the fluid.
  3. #3
    Join Date
    Dec 2003
    Location
    New York
    Posts
    700
    Default
    Water. Surprised it drained out and wasnt frozen up. Glad it worked out for you. You may want to use it a little and flush it back out again. Get that leak fixed!
  4. #4
    Join Date
    Dec 2003
    Location
    indiana
    Posts
    1,234
    Default
    Quote Originally Posted by btammo View Post
    Does the leak allow enough water in to turn it milky?
  5. #5
    Join Date
    Dec 2003
    Location
    New York
    Posts
    700
    Default
    Sure. Doesnt take much to get in especially if it has been sitting around awhile. I would flush it, use it and then flush again....
  6. #6
    Join Date
    Nov 2002
    Location
    upstate New York
    Posts
    2,299
    Default
    Yup. Had my myers freeze up, knew it was that because I put heat on it, & in about three minutes, it was working. Lift ram seal is iffy, I think moisture is getting by.
    Conan, what is best in life? To crush the Democrats, to see them driven before me, and to hear the lamentation of the liberals.
  7. #7
    Join Date
    Dec 2003
    Location
    New York
    Posts
    700
    Default
    I had 3 plow freeze up this year and smoked 2 pump motors in the meantime
  8. #8
    Join Date
    Nov 2002
    Location
    upstate New York
    Posts
    2,299
    Default
    I am going to rebuild the myers e-60. Got a buddy of mine that has the necessary equipment to do it. Fisher minute mount has been good, no issues. looks like more snow coming in this coming week. spent many hrs plowing Wednsday & thursday .
  9. #9
    Join Date
    Nov 2002
    Location
    upstate New York
    Posts
    2,299
    Default
    Found the problem with the myers. Water had gotten in the end of the motor, & when it got cold, froze up, motor would not turn. Pull motor, drain completely, good to go. Note to self, when installing a new motor, make sure there is a drain hole facing down on motor case.
  10. #10
    Join Date
    Dec 2003
    Location
    New York
    Posts
    700
    Default
    I siliconed around my motors when I put them on this time. Doesnt say to do that but i fugured it couldnt hurt. I had ice around the motor shaft as well. Nice design huh....
Similar Threads
  1. bobcat hydrostat fluid
    By dan nelson in forum Commercial Equipment, Trucks & Trailers Forum
    Last Post: 08-22-07, 03:02 PM
  2. changing out hydro fluid
    By LLee in forum The Repair Forum
    Last Post: 01-24-06, 04:38 PM
  3. exmark hydrolic fluid and filter
    By steve-o in forum Commercial Equipment, Trucks & Trailers Forum
    Last Post: 02-27-05, 12:22 PM
  4. changing hydro fluid
    By XtreemGreen in forum Commercial Lawn and Landscape Maintenance Forum
    Last Post: 03-29-04, 12:22 AM
  5. Hydraulic Fluid
    By dancom in forum The Repair Forum
    Last Post: 03-09-03, 01:49 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
