Power Washing Chemicals
  • Power Washing Chemicals
    Hey guys/ladies.
    What chemicals do I need to get for pressure washing.
    House Exterior:
    Vinyl:
    Brick:
    Asbestos Siding:
    Drive/Walk Ways:
    Roofs:
    Any thing else you can think of and where do you get the chems.
    E.Cole
    Perfect Gary.
    Now you use bleach for pretty much everything, is that right. I have been told use chlorine, since it cleans the same but is generally more potent but no discoloring problems like you could encounter with bleach.
    E.Cole
      Hello Everybody:
      I've used Bleach & Chlorine both. Never had a Problem & It's Because...
      I Allways wet all my Surfaces first with just plain water, yes including my bushes or anything else that I think will get hit with the Spray & Over Spray. I Never let it dry either.
      Then I apply my Chemicals Always starting at the bottom going upwards in a Left to Right Motion.
      Then I Power wash Starting at the Top going down. When Completely Finished Washing Surface I then go back & Rinse & Rinse with just water. Yes the Rinse & Rinse off the Bushes T00!
      I Never Ever had a Problem with Discoloration or any Bushes Dying on me or even getting a Little Damaged!
        Thanks fellas.
        E.Cole
          Gang,
          How do you charge. I know a round about on how much you charge, but how do you charge. By the sq.ft. or what. I don't know how long it takes me to clean because I am yet to do it.
          E.Cole
            Gary, Thank you, no one else responded on this in several days. I needed to know this before I get started. I am going to do my advertising soon.
            E.Cole
              COLE, buy chlorine.
              chlorine is basically the same as bleach but 4 times stronger!
              I buy 2.5 gallons of chlorine at the local pool supply for $2.00 that 2.5 gallons will make 10 gallons of "bleach", a gallon of bleach in the grocery store costs about a $1.39 x the 10 gallons you would need to = 1 2.5 of chlorine is $14.00. Which would you rather buy to get the same results? I use a 5:1 chemical injector to apply the chemical, I put the injector hose directly in the chlorine jug.
              I usually do 6-8 jobs a day and have never had a problem with discoloration or streaking or killing plants or grass. During a full day i will use 10 jugs of 2.5 gallons of chlorine, if i was using bleach this would cost me $140.00 a day and I would not be able to carry that many gallons with me. The chlorine costs me about $20.00.
              I charge the following: whole house consisting of exterior, pool deck and enclosure, 2 car dw/sw - $185.00 it takes two of us about 1.5 - 2hrs. We price right at $50.00 per hour per person.
              house - 75.00 up to 2500sf living 1 - 1.5 hrs one person
              roof - 200.00 less than 1500sf living
              250.00 1500 - 2300
              275.00 2300 - 3000
              300.00 3000 - 3500 will take one person about 4 hrs. with surface cleaner.
              pool deck and enclosure - 75.00 - 85.00 single story, double that for 2 story. 1.5 hrs single story
              dw/sw - 45.00 2 car, +5.00 cornor lot, +10.00 3 car. 40m 1 person 2 car.
              Chlorine works faster so you can also.
                Bubba I thank you as well for all the info. I can get chlorine cheap too. I was going to use it any way. While the active ingredient in bleach is chlorine. You chlorine doesn't discolor like bleach. And bleach will discolor, did a test this past weekend.
                  Gary or anyone for that matter. Gary recommends anyone going into p/w biz needs to subscribe to Cleaner Times Magazine. www.cleanertimes.com Has anyone else used this. Either way I am subscribing. Also, have any of you ordered any of the manuals or videos on the site. Seem to be kinda pricey but look to be good info.
                    hello everyone, i;m a new guy to the site and i hope i can clear up a little confusuion on the chlorine bleach. bleach is 51/4%chlorine, so the chlorine i think you are refering to is in the 21/2 gal jug witch is pool chlorine and that is 10%chlorine. if you mix pool chlorine 50 50 with water you will have blaech strength chlorine. the discoloration talked about may be due to the stablizers in the bleach that give it a shelf life. chlorine does'nt have a stable shelf life and loses it's strength rather quickly. don't know about presser washing costs, hope i have been of some help. stay dry lol.
                      Hello everyone. I was wondering if anyone has used oxy-clean or any of those oxygen cleaning powders for p-washing.They say on the back how to mix for deck cleaning & mildew removal. I have been using bleach for everything the only thing I have seen with bleach is that when you use it on sealed surfaces it eats threw the sealer and strips it off. This is why I was wondering about Oxy-clean since it is supposed to be so safe for cleaning I was wanting to know if it will clean the mildew and dirt but not hurt sealers on wood. I was also wondering if the cheap bleach is just as good as clorox. I just tried the Armoral EZ-Deckwash from Wal-mart $2.79 a gallon and it worked great on this very very bad mildewed new home that was not sealed. Tried bleach too but the Armoral worked alot better.G-Man did you have any luck with your $49.95 driveway special?
                      Thank You! A Affordable Lawn care & Pressure cleaning
                      Thank-You!
                      Donny & Cynthia Moore
                        Anybody ever use TSP? It's supposed to be some heavy duty stuff. I think it's mainly used for drive-thrus and dumpster pads. Just guessing.
                          Hi im new to the forum & I wanted to know the brand of the chlorine & where should I buy it from. For the longest of time, i have just used simple green & bleach. Please notify me of the brand name that works really good and where I should buy. Thank you
                            go to your local swimming pool supplier, they should carry 10-12%. The stuff you get at the grocery store or wherever else is normally only 4-6%.
                              hi is this a liquid form or other form.... most places out here only sell 60% and higher...... just notifiy me of any place online that will sell this 10-12% thanks.
