Es210
  • Es210
    I have several Echo Blowers, and 3 ES210's. One of the 210"s is stalling out after about 10 minutes of use. It is fine, then is get's weak, and dies after 10 minutes. If it cools down it will run again, but dies after about 10 minutes.
    Any suggestions, the plug is fine, air filter fine, rtc.
    John
    Quick Check... FUEL CAP...
    John
    Gas cap vent defective leading to a vacume buildup in the fuel tank as the engine runs and the fuel level drops resulting in fuel starvation...
    Try leaving the cap slightly cracked open, or swap cap with one of your working machines... If you leave cap open ,be careful to make sure gas doesn't splash on anything hot, and see if it solves the problem...
    If it helps replace cap ...
    GOOD LUCK ,TRANNY...
