Actually, I suppose this is more of a hydraulic lift problem.
I just picked up a 08 729G2 GH used (only had 8.9 hours on it). It does not appear the deck was ever adjusted. I am curious how I can adjust the space between the switchmount/control box and the actuator...
As it is, I can only lower the deck to 2.5" without reaching down and lifting up the control box. I normally cut at 1.5" to 2" and would like to use the memory spacers, but using any of them makes the cut even higher. I claim to have studied it well, but I just do not see how this is adjusted, but surely there must be someway to adjust it. It does not appear the actuator mount can be moved unless new holes are drilled and the control box cannot go any further back.
Does anyone know of a way to adjust or remedy this problem?
Many thanks!
Many thanks!
