anyone using them?? hear of or have anytroubles with them? We bought one new for a new crew location this spring and it was bad but we got them redesigned and more then likely can help if anyones had problems now its the best mower we have by the crews views on it . anyone with feed back?
husqvarna 48'' 15hp walk behind with ETS system anyone using them???
the original problem , and how majopr it was started within 3 hours the belts on it had run out of adjustments on the drive system and it had not hurt the belts . the unit would run fine for 10 minutes and start to slip where it wasnt tight enough anymore . turns out the spring on hte units are setup weak and wont alow a sulky to be pulled without this issue the fix is a 5 minute fix and it is great the only down fall is the hand grip gets harder then normal but its a factory backed repair and you do it yourself.
you simply take the spring at the tensionor for the belt off at teh bolt not the pulley ......then strech it down and hook it on the lower rear bolt on the drive guards this causes the springs to have more tention durring the engaged opperation and the only thing is it makes the hand grips tighter , not alot just some tighter but it will pull 100 times stronger.
