I just replaced all the belts on my exmark metro. The right hand drive belt used to slip on the pulley that is attached to the transmission... now that I replaced the belt it grabs on that pulley but slips on the larger wheel pulley... it only does this when I am on a hill and I stop and then start again...
Brakes are all adjusted properly...
I have tried cleaning the pulleys and even roughing them up with a little 80 grit sandpaper... also I have moved the spring to the highest tension position.
The belt grabs sometimes, but not with the grabbing power of the belt on the other side... I cannot hold back the mower then I let the left wheel go, but when I let the right wheel go I can hold the mower back if I pull hard and the belt will start slipping
Any ideas? Thanks!
Eric
Any ideas? Thanks!
Eric
