Mower Deck Swival Caster Wheels
  • Mower Deck Swival Caster Wheels
    All the ZTR's I have seen have stationary mower deck wheels. I have found that I dig into a lawn now and then when I turn due to these stationary deck wheels.
    I have the optional swival castors that I normally use and had to put the standard wheels on for a day or so due to having to replace the bearings on the castors.
    Does anyone else have this problem with the front deck wheels digging into a lawn when turning? Do I have to adjust something to keep this from happening?
    Wayne
    Hi,
    While I don’t know if its true for all ZTRs, the manual for the exmark 72" ZTR says to set the anti scalp wheels 3/4" above the desired cutting height.
    Set this way, I have not had any issues with the wheels damaging the lawn. That said, I did have them set 1/4” once and that did cause issues.
    Branwell
