I have a Toro 32" recycler mower with a 13hp Kolher. The engine is about shot but the chassis and deck are in good shape. I have an almost new 15hp Kohler and was wondering if anyone has ever made a swap to a larger hp engine? I know it shoud fit the chassis but was concerned that it may over power the blade. I would appreciate any input.
Toro engine replacement
yes
Pretty easy to do. Check your bolt mounting patterns to make sure they are the same. Also shaft length and diameter. 2hp wont make a very noticeable of difference in power, maybe a little less bogging in wet conditions or over growth.
As for over powering blades
Just set RPMs to get correct blade speed.Fear eats the soul
