I am currently working out of a Ford F-250 and for the past two years been bagging everything. This sucks especially with fall cleanups, very time consuming. I am thinking of putting in sideboards and just loading leaves in loose. Will this save a lot of time? Will I be able to haul as many leaves(they are compressed in the bags)? Will a tarp work for fast unloads or is the load too great. I'm talking about one 10 hour day of leaves.
Leaf Cleanups
That will help with unloading and your local law enforment officer may issue you a summons for failure to secure a load.
I would see about sides and atleast tarping the top, or a full enclosure and a leaf loader which would save you a ton of time and the reduction of the leaf matter would allow you to haul a lot more at once.
Here is what I had been thinking of doing.
Buy a Billy Goat lawn vac and material handling vac.
Put the material handling vac onto a trailer that has been covered with canvas or burlap.
When the billy goat is full, simply go over to the trailer and dump the leaves next to it, then when its all done, suck em up with the material vac into the trailer.
For unloading, rig up a special skid towards the front, and run a chain out the back.
When I get home, hook the chain to the tractor and pull off the leaves.
This is how I've done it the past three years, but without the vac truck. Truck and trailer all day...gets old after a while, but it works.
Once it gets too heavy i just tarp them loose into the back of my pickup.pack them down by walking over it several times.When full, i cover with a tarp, put some weights on the corners so it doesnt blow off and head to the dump.Not as good as a leaf loader but it sure beats bagging.Eastern Lawn Care LLC
Leaf loader kicks butt, really is the best way to remove a lot of leaves quickly.We have our 11.hp leaf loader on our dump on a swing arm, with an enclosed box, holds around 9 yds shredded leaves.Takes less than 5 minutes to dump and head back to the job. Saves time, energy, your back, and your help.
Originally posted by avelli2000Mariner, what size properties are you doing? Most of my accounts are 60X100, pretty small stuff. Does Jack D's method work on small props?
