Whats the going rate on stacking around drain pipe of driveways. Planning to use some mortar. just not sure the time it takes so not sure on the quote. 200 for a pallet of rock is average in the area. Also is 1 pallet enough to do both sides on average?
rock work
I Buy Mine In Bulk........
Originally posted by j2short View PostWhats the going rate on stacking around drain pipe of driveways. Planning to use some mortar. just not sure the time it takes so not sure on the quote. 200 for a pallet of rock is average in the area. Also is 1 pallet enough to do both sides on average?
Bag stuff???
Originally posted by delasgh View Postvery seldom do i use the bag stuff unless it's around a couple of pipes and that's it. you can figure how by length x width x depth = ? / 324 = cubic yards needed. hope this helps. keep in mind the size of the rock also.
"stacking," "mortar."
You deserve a real answer...
Drain pipe you say? What size?
How wide and tall are you stacking?
How much rock is on a pallet? Yes, it varies.
Do you really need to use mortar or dry stack? Depends on the stone you are using and the application.......
How much prep work is involved? How much digging? Soil type? Native rock present?
Once you have this information you could answer your own question. :alien::alien::alien:
