Shat are the best blades for mowing Bahia I'm tired of mowing twice to get a nice cut and it dulls blades so fast
What are the best blades for Bahia
blades
Try getting more blade tip speed by increasing your engine rpm's, helped me this year with a 2 week customer who had fert. applications. I mow about
10" off the top.sigpicwww.360lawnservice.com
812-236-4806
Terre Haute, IN Lawn Care
360 Lawn Service
"Cutting Edge of Lawn Engineering"
Also, you can try only cutting in the morning when there's a bit of dew on the grass, it helps give it wiehgt for the high lifts to pull it upright.
Worst case scenario, you have to modify a mowing deck with big notches all across the front of the deck (like teeth on a grading rake) to insure the rigidity is maintained. The front edge of the deck pushes the long blades over, and the faster the ground speed the less chance the grass can pop up and be cut off. By cutting the open spaces into the front vertical edge, you keep the grass more upright. Vacuum is lost, but you'd still want the high lift blades to eject the clipping further.GEEVEE®, Pat.Pend. TM, UL
