small enclosed trailer question
  • small enclosed trailer question
    I am looking for a 12` single axle enclosed trailer with a side door ,which is common.
    I need a trailer with a width of 76" and I can dont find one.
    The trailer shop in town only offers a 67" wide single axle12` or a 80"dual axel 16`
    The max load will never exceed 1700Lbs
    I need it wide enough to fit #2 ztrs. A 30" and a 46" in 9` of the floor. To achieve this the 30"ztr will have to be turned sideways. The 30"unit is 66" but will need space to rotate while not rubbing the walls..
    Does anyone make a 76" or 82"wide single axle witha 3500lbs /5200lbs axle????
    I found a trailer company 80 miles away who will build me any size length/width /axle width combination I want. I priced a 8`x 12`82" axle width single axle for $1000.oo
    and a 8`x8`/82" axle width single axle for $700.oo
      Is this a open trailer for $1,000 that sounds VERY cheap for an enclosed have you seen there work?
        Dearest Abby,
        This sounds cheap for a trailer, much less an enclosed trailer..................
        Confused in Kansas... 2 houses down from MM................
        I am the one and only YardRat! Just call me "The Rat"
