Don’t make these common lawn watering mistakes
  • Don’t make these common lawn watering mistakes
    Keeping your lawn hydrated is important. If you are not watering it may lead to drought and dried grass. Whereas, watering too much to your plants will damage your lawn. It can be said that lawn care in the art that you need to build over a period of time.Affordable lawn care can be obtained by just maintain the right amount of water in your lawn.
    The problem may arise when you start to take too much care of your lawn but in a wrong manner. Experts suggest that too much watering can cause damage to your plants leaving it damp and open for fungus and insects. Here is a list of things that can prove beneficial in your efforts of lawn care.
    1. OVER-WATERING:
    Over-watering your lawn can cause significant damage to your lawn leaving it a damp place for fungus and insects to grow. So, the question is good enough during the week? Lawn care experts suggest that up to 1 or 1 and a half inch of water is enough for the plants .2 good watering will be enough for your lawn in a week. This will make your plants resistant to weather conditions and grow as lush green and healthier. It is also important to note that proper watering will also save water from wastage.
    2. WATERING DURING HOT DAY
    As the correct amount of water is important so is the correct timing is equally essential. Watering at wrong hours will not benefit your lawn. Often people make the mistake of watering the plants during hot summer afternoons. It causes the water to evaporate and is not absorbed by the water and roots. This is a huge waste of water and time. The proper time to water your plant is around 4 a.m. to 10 a.m. in the mornings. This is the best time to water your plant keeping it moist and allows the deep penetration in the soil.
    3. USE OF SPRINKLERS
    A built-in sprinkler is always recommended for the lawn. Professionals suggest that a pulsating sprinkler is more favored than the oscillating one. However, if you have new grass system an oscillating system is advised. On the other hand, pulsating sprinkler allows deep penetration of water into the soil.
    4. PUTTING SPRINKLERS ON AUTO-PILOT
    Sprinklers are a good option to choose from as they save time and manual labor. But it can damage your lawn if not executed perfectly. If you set the sprinkler on autopilot it will not be able to adjust according to the need of changing weather conditions. For example, there is no need to water your plants if it's already raining it will leave your place wet and soggy open for fungus saturation.
    5 WATERING THE CORRECT AREAS:
    It’s important to water your plants to correct areas roots is the place to target when watering your lawn. It should be made note that for grassroots should be focused rather than blades and roots over leaves.
    These are common lawn watering mistakes everybody do, you have shared very informative post on this topic, everybody should follow it.
