Catch my mower..too fast
  • Catch my mower..too fast
    I recently bought a used commercial Honda 21" HRA 216 mower that runs too well. How do I slow it down? The self propelled speed setting is turtle but the mower runs like a deer. That is the slowest setting, help please. Thanks
    "is turtle but the mower runs like a deer"
    I thought you bought a Honda??
    Check and see if the cable is broken or stuck in the "rabbit" position.
      Have your RPM's checked, Honda mowers with say various speed settings are fixed settings & on most walks there's really no way to slow the machine down except lower your engine RPM's.
      On that Honda, I would not run it under 3,200 RPM's. Are you sure it's actually changing gears & it's not stuck in one speed setting. I see that a lot, where the mower will have a stuck or broken cable in second or third gear.
        It sounds like you are talking about the 2 speed, with the shifter on the deck? As far as I am concerned, there is very little difference between the two settings. If you want a true speed difference, get the "hydrostate" variable speed shifter, its worth the extra money.
          I was wondering how much the the honda commercial mowers cost?
          1993 Ford F-250
          16ft Landscaping Trailer
          2004 Walker GHS 48" 26hp EFI Power Dump
          2002 Walker GHS 48" 26hp EFI Power Dump
          2004 Hustler Fastrak 44" 18hp Vac Bagger
          Honda hr215 21" mower
          2006 Honda Commerical 21"
          Redmax 8000 blower
          2 FS 110's
          FC 110
          FS 250
          FS 76
            In WA around $1100. In Alaska, the price is probably inflated due to your remoteness.
