Major Sedge Problems In Hooterville................
  • Major Sedge Problems In Hooterville................
    i got more yellow nutsedge and green kyllinga this year than ever. i don't really have a good answer other than the wet and snowy winter we had that saturated the soil so good. the spring and summer here have been a drought. the stuff is going crazy in all the lawns. anybody else having a problem????
    steve-o
    Sedgehammer
      Steve-O doesn't buy into the Sedgehammer deal....works good here though.
        Sledgehammer then?
          Let Me Make This Simple For Yankee And College Boy..........
          i just wanted to know is any other areas of the country having more issues than normal with this sheot.......... it seems that the hooterville metro area is nailed big time this season. ALSOOOOOO, i know what to treat it with. here in hooterville i'm using prosedge which has the same AI and % as your sledgehammer does........... thank you for your concern.......:laughing:
          steve-o
            Nah, all is normal here...
            How does the cost compare with what you're using to Sedgehammer?
              $95.00 Plus Tax In Hooterville.........
              you need a good sticker too. i'm sure you still use dawn. 1.3 oz bottle gives me about 40 gallons of spray. i pretty much go with 1 gram per gallon, but you can use 1 per two gallons on the lean side. don't know if you ever have sprayed it or not, but use a flat fan nozzle on your backpack if you have heavy infestation like i do in hooterville. cone is fine for spotty areas. i'll be spraying again tomorrow. it's tricky doing your mowing customers in order to have it growing and then not mowing too soon afterwards.
              steve-o
                It's bad in Virginia too.
                steve-o
                I think sedge thrives on this weather.
                  Hooterville, Virginia................
                  i'm thinking sedge thrives in my hoods.........:alien: $$$$$$$$$
                  steve-o
                    IT'S ALIVE!
                      old post but mix atrizine 3/4 oz and basagran 1/2 oz per 1000 and u have a knockout sedge killer
