Roundup...what's up!
  • Roundup...what's up!
    OK, I'm no noob but lately I've been doubting myself more and more. My roundup apps have become less and less effective in last year or two. More over the weeds just burn down for three weeks and sprout new growth just below the dead foliage, and some weeds don't even flinch. I've been using Roundup for near twenty years and didn't start having these problems until I switched to ProMax and then to Quickpro. Anyone having similer problems or have any suggestions. I just read an article on glyphosate resistance, I hope this is not the case. I included the link below.
    Figure out how QuikPro works and you'll have your answer. Might be wise to switch over to generic 41% glyphosate.
      try checking the ph of the water you use because that will make all the difference in the world between success and failure.
        I have the same problem. Anyone can help us here?
          Problem Solved................
          [QUOTE=Heatstroke;226155] I've been using Roundup for near twenty years and didn't start having these problems until I switched to ProMax and then to Quickpro. Anyone having similer problems or have any suggestions.
          switch back to Roundup. for the record, i use Quickpro without any problems. if it's mixed correctly it should do fine or do as college boy said.
          steve-o
