Snow Plow Maintenance Checks
  • Snow Plow Maintenance Checks
    Plow assembly maint checks ...
    . Raise plow assembly
    . Operate each control
    . Check hydraulic lines for leaks
    . Check plow lift chain for wear
    . Check plow pump belt tension
    . Check cylinders for leaks
    . Inspect outer "O" ring wiper seals
    . Inspect linkage pins, retainer rings
    . Test upper & lower plow light beams
    . Operate turn signals
    . Check all plow welding points
    . Check plow frame attachment
    . Inspect lower scraping blade bolts
    . Reposition plow blade markers
    . Inspect all quick disconnect fittings
    . Check head lift cylinder for drift
    . Inspect plow spring assemblies
    . Grease contact points on plow
    . Check if blade interferes with vehicle when angled to full right or full left.
