Anyone ever replaced the engine on a Honda HRC216 with the GXV160AA12 Honda engine from Northern tool? Does this have the connection for the hydrostat transmission?
Replacement Honda HRC216 engine
I think this
Isn't your hydrostatic pump run from the crankshaft??????Originally posted by P&C Lawn Care View PostAnyone ever replaced the engine on a Honda HRC216 with the GXV160AA12 Honda engine from Northern tool? Does this have the connection for the hydrostat transmission?
http://www.northerntool.com/webapp/w...3573_200333573
You will probably need to measure the crankshafts length and size then see if its the same as the one northern tool sells.....
Some machines have totally different cranks that are threaded , or tapered and you have to get the correct one.....
Regardless you have to have the same crank design , dimensions / and size or the engine will be useless for your particular application so you need to tip the mower over and see what crank you have and carefully measure it.......
Have you checked :
Click under honda of coarse and see how many different cranks they have for that size / HP vertical shaft engine.....
Tanky........
T
Or
tulsaenginewarehouse.com
I bought a Briggs from them at one heck of a deal.
They buy Sears closeouts along with others. Call and ask them the guy I talked with was SPOT on and told me that if it does not fit, I could have it free that he was that sure.
T
I have T copyrights with the bouncing monsters icons
SO BEWARE !!!!!!!:laughing:Originally posted by Spoiled View PostOr
T
http://www.tulsaenginewarehouse.com
I wanted to view it so added the link while looking so good find regardless Spoiled.....
T
Why thank you...Originally posted by TRANSMAN View PostSO BEWARE !!!!!!!:laughing:
T
I did deliver 100 bales of pine today. That was easy money for a Sunday.
