Other than the Magna-Matic, which is about a grand out of my price range, are there any outfits offering a quality dedicated blade sharpener, especially one in the $200 to $400 range? Or should I be expecting nothing more than a glorified bench grinder at this range?
Dedicated Blade Sharpeners
I'm in the same boat on this. It's obvious the Magna Matic is the only true "official" sharpener for us mowing folk, but I to wish there was a less expensive dedicated solution. Everyone sharpens their blades a different way, but it ain't always the optimum.
hillndale
In the past, I had the shop do it. Cost back then was $5/each blade. With 3 blades that is $15 per time. Once you start doing a lot of lawns, it will become very expensive. And don't forget about the time it takes to drive to the shop, wait your turn, etc. When the price hit $6/each blade at the shop I went to, I decided to do the sharpening myself. After much research, I decided to go with the Magna-Matic. The Magna-Matic is easy to use and productive. If you are doing a lot of mowing, it's the way to go as far as I'm concerned.
PNA1996 Ranger 3.0 pullin' 5'X11' Tandem Open Trailer
Toro 44" ZTR Kawai 17 HP & Quick 36 SD Kawai 16 HP
Stihl FS-80 Trimmers & Stihl FC-75 Edger
Stihl Hand & Back Pack Blowers (BG-85 & BR 550)
Stihl Chain & Pole Saws (MS250 & T-101)
Once you set it up (raise / lower wheel) as necessary to match the angle you want, just run in back and forth along the wheel and check for balance.
