In an attempt to dispell some of the ignorance shown on the subject I will adress some of the more fantastical perceptions.
<BLOCKQUOTE id=quote><font size=1 face="Verdana, Arial, Helvetica" id=quote>quote:<hr height=1 noshade id=quote>
If they do no damage, and make for a better cut, why don't the companies start mass producing these blade set-ups?
<<Don't Fear the Green!>>
<hr height=1 noshade id=quote></BLOCKQUOTE id=quote></font id=quote><font face="Verdana, Arial, Helvetica" size=2 id=quote>
http://www.walkermowers.com/index.htm1?section=tractors
http://www.gravely.com/PProG_Accessories
http://www.dixiechopper.com/
Will I get a better cut if I use 4 blades on each spindle?
No, you will drag down the engine,.
I hate sharpening blades, now I will have 21 per mower? Well, I'll pass it on to my clients. Toots.
You don’t need to sharpen the top blade often. The bottom blade cuts the actual grass plant. The top blade increases velosity & size of discharge or chops leaves to dust in mulch mode.
Doubles can eliminate bagging spring growth and fall leaves.
