How many square feet are in an acre? When I measure with the wheel, I take LxW, which gives me sq footage. Then I divide that number by the number of sq. footage footage in an acre. Right? That's why I need to know how many sq. feet are in an acre. Thanks
sq. feet in an acre
Hello grassmoneymaker:
Go to this link!
http://www.lawnservicing.com/forum/topic.asp?TOPIC_ID=2742&SearchTerms=acreGrassMaster, LSF Administrator!
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by qualitylandscaping</i>
<br />Correct number is 43,560..
<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Steve is correct. [
Quality Is Good ©
The area of a property that you are going to give an estimate on is the starting point for the estimate for me. Then you will need to calculate in the areas that need to be stringtrimmed, edged, the difficulty of mowing (ie. hills, if property is cut up, if property is all open etc.)Wayne
The site is adult???
I cut and pasted this link and it brought me to an adult orientated site. Nothong there for conversions lol, maybe put in wrong sizeOriginally posted by richmondresTry this link also. This is an area conversion calculator.
http://www.makaandukaan.com/calculators/areacal.asp
Originally posted by grassmoneymakerWhen you take LxW divided by square footage in an acre, what do you do then? What does that number tell you? help! [:0]
why are you dividing it by an acre's square footage? You want the area sq. footage for what you are doing, L X W..that's it. The only reason to add the step of dividing by the acre sq. footage is to determine how many acres or % of acres you have, but that does nothing for figuring your sq. footage. Example. area is a rectangle 400 feet by 720 feet (400 x 720= 288,000 sq feet)...there is your area. If you want to know how many acres that is THEN divide by 43,560 ( Area / Acreage sq. ft =) 6.61 acres in the above example. Hope that helps.
