help needed for a 1032 snow blower
  • help needed for a 1032 snow blower
    John Deere 1032 Snow blower with Tecumsah motor. We have it almost running but are not sure which hole in the Throttle Boady? the Governor wire goes into. anyone have any idea, sounds like it idles really high, and we cannot keep it running. We broke the bottom of the float Jet, Brass connector with spring inside, so we dyed a part from a lawnmower to get it to fit in the carb body, so its getting fuel.
    from front of engine, Choke valve, bowl, and just above it a semi circle with like 6 or 7 holes in it. which hole does the rod go into?
    sigpic
    Spring fever.
    Safari Better Get His Sheot In Order...................
    more tomorrow and saturday. i just drink this time of year.
    steve-o
    "THE BADDEST LAWN APE ON THE PLANET"
      steve-o
      Gotta come up with a back up plan, Axle should be done tomorrow, providing it got delivered to dealership tonight from Baltimore. Right now calling for 14"-25"
      sigpic
      Spring fever.
        Look under magnification if needed, for witness (wear) marks at the edge of the holes or on the under side of the lever.
          Did you get it hooked up right?
            I am going to try to work on it tomorrow, We have talked about just making it a project and remotor it this summer.
            sigpic
            Spring fever.
              I have had the Carb which finally came in like in May laying around and put it on today, it started first pull, But I seem to be missing something, Spring or linkage from the throttle to the motor, anyone have a 1032 snow blower? I will take a picture and post it, but if someone can post a pic of the offending area so I can figure out what I need. The dealer is about an hour away but if I could see the picture I can fabricate something.
              sigpic
              Spring fever.
                sigpic
                Spring fever.
                  almost running) lol) it wouldn't almost running with wrong hole.
                  it early for you have problems in business? search solution for term papers
                    I Oredered the correct SpeedSpring that I need, I finally found it, its not listed in parts for my spec.... I just have to idle it down, it workedpretty good today with th elittle I used it. Spring should be in Jan 3rd.....
                    sigpic
                    Spring fever.
                      Hey! Have you ever work with PowerPoint? I need some help with a PowerPoint presentation. I am in stress.
